1 - 8 of 8 Posts
Discussion Starter #1
Has anyone upgraded or updated their binnacle lights?
At night, I can see my instruments, but it is pretty dim
My dimmer dial works
Is it possible to switch to LED?
I have to pull my cluster soon to repair speedo cable and would love to brighten up my dash lights.
Any help would be greatly appreciated
very disco
I did this in my 88 Jaguar xjs, upgraded everything to LED. It ended up being too bright and overpowered the coloration of everything. Also the dimmer control became an on/off dial with a chance of damaging the cheap LED lamps. Your mileage may vary
Expert Crate Digger
Adding LED bulbs to the binnacle mad easy. If buying on ebay, go with a reputable LED store.
91513
91514
The dimmer dial never allows full power to the lights. I simply added a switch that bypassed the dial. The dash lights are a lot brighter. I installed a simple 2 way with. Switch it one way and the dimmer still controls the lights, switch it the other way and it is bypassed.
Discussion Starter #5
Thats interesting. I will first try to bypass the dimmer switch
I think my warning lights are brighter than the lights that are on if I hit the headlights.
Maybe I can just replace those dimmer ones with LED? Maybe it woudnt be overly bright???
Does anyone have info on what LED to buy? Is there a specific name or part number.
Seems like there are a lot of different ones.
Thanks all
very disco
Maybe I’m too fussy, but that upgraded LED image is what I had, and I didn’t care for it. Everything is the same color, and there’s much light-bleed because the unit wasn’t designed to trap nearly as much light as the LED puts out. Not to mention, it no longer matches the rest of the dashboard illumination.
Expert Crate Digger
To match the binnacle, I changed to Blue LEDs in the clock/door lock switch, climate controls, all 8 window buttons (4 in doors & 4 in center console).
The only ones still green is in the gear selector and the button for the sunroofs.
At times it can get too bright and lit up like a nightclub in the cab when the climate controls and window buttons in the center console are on. The dimmer switch somewhat takes the brightness down to about 800 lumens. lol
very disco
Haha yeah. That’s bright AF
1 - 8 of 8 Posts
