1 - 5 of 5 Posts
Brake Vacuum Pump
Mechanic told me the vacuum pump is the main leak I need to consider fixing. Anyone messed with this. At work so I dont have the workshop manual with me. Quoted me at around $600. Found it on one site besides local land rover dealer. Not sure if its what i need because it has no pictures. He told me vacuum pump sits under the air cleaner. The truck is at the shop until tomorrow. Any suggestions on whether or not I should do it myself? Anyone have any good links for Land Rover Parts?
https://www.partswebsite.com/landro...ection=18&catid=10028&subcatid=20079&fl_id=38
Discussion Starter · #2 ·
Nevermind
Power Brake Actuation - Brake Vacuum PumpI6 3.2L Petrol
Removal and Installation
Removal
• NOTE: Removal steps in this procedure may contain installation details.
Remove the cover and disconnect the battery ground cable.
Refer to: Specifications (414-00 Battery and Charging System -
General Information, Specifications).
1.
Remove the engine cover.
Refer to: Engine Cover - I6 3.2L Petrol (501-05 Interior Trim and
Ornamentation, Removal and Installation).
2.
Remove the battery tray.
Refer to: Battery Tray (414-01 Battery, Mounting and Cables,
3.
Remove the air cleaner assembly.
Refer to: Air Cleaner (303-12B Intake Air Distribution and Filtering -
TD4 2.2L Diesel, Removal and Installation).
4.
Remove the A/C compressor, upper support bracket.
Torque:
M10 45 Nm
M8 25 Nm
M6 10 Nm
5.
Disconnect the brake booster vacuum line from the brake vacuum
pump.
6.
http://topix.landrover.jlrext.com/topix/service/procedure/146634/OD...
1 of 2 29/10/2011 15:21
7. NOTE: Make sure that this component is installed to
the noted removal position.
Remove the brake vacuum pump.
Torque: 17 Nm
7.
Installation
1. NOTE: Make sure that the component is clean, free of foreign
material and lubricant.
To install, reverse the removal procedure.
I think I narrowed it down
So I took apart the brake vacuum pump from the engine, looks like there is a sign of leakage. Mechanic told me that you have to buy the pump because there is no breakdown. This is correct for the break apart of the pump, there is a seal that mounts between the pump and the engine though. I think this is the culprit. Damn, I should have taken pictures.. Will post some when I replace the seal. Oh by the way it is not a standard size o-ring seal you would find in a kit. If this is the case, I will be saving almost $600. :buttrock:
Discussion Starter · #4 ·
Vacuum Pump Ordered
Looks like the seal wasn't the problem. It is the pump housing leaking. Wish I could find a rebuild kit for the pump instead of sinking $204.00 into a new pump. Anyone know where to find rebuild kits for pumps like these? The part # for the vacuum pump is LR009388 and the seal that seals it to CVT housing is LR017021.
LR2 has same 3.2 engine as Volvo S80 and the vacuum pump does appear rebuildable with Volvo kit:
Kit: Volvo OEM Rebuild Kit (31401556) $64 for 2 seals and new screws at local Volvo dealer.
Pump: Volvo OEM Brake Vacuum Pump. Part No. 31401152 & 31219778 (pump will actually show 6G9N-2A451-AF (or AG or AH). It's a FoMoCo (Ford) part made in Germany.
My LR2 pump is actually stamped with FoMoCo (Ford) 6G9N-2A451-AF.
I am original owner, so I know it came this way from LandRover factory.
Google/ebay for pics and prices and rebuilt pumps for about $150.
It looks pretty easy to replace.
Just pop-out the airbox, then remove battery and battery tray
2 bolts secure pump to top right-side of engine.
May need to remove Top Alternator Bracket (2 more bolts)
1-2 hours, maybe. Any mechanic or mechanically included person could do it -- way cheaper than LandRover dealer
Search Youtube for video titled: "2008 Volvo XC90 brake Booster Vacuum Pump Rebuild"
Things you have to remove to get to pump are a little different, but give good overview removing pump itself.
1 - 5 of 5 Posts
