Steering...
:drive:
Steering Vibration / Shudder
The 4.0/4.6 has a much better steering box and system than the Classic. However it is of the same basic design, and some owners have reported the steering judders upon going over bumps at speed that are so notorious and common in Classic models. If you have checked out all the ball joints and tie rod ends, the most likely cause is the steering box needing adjustment. Like the Classic, the 4.0/4.6 steering box has an adjuster on top -- this one has a screw with an internal hex and locknut. Jack up the front wheels and screw in the adjuster until there is minimal play in the steering at dead center. Then turn the wheels lock to lock to make sure there are no tight spots. The other thing to check is the swivel pin bearings, which need to be kept adjusted as per the shop manual, or replaced. Ian Dugdale (Ian at Dugdales dot com) had this problem and after trying the usual remedies (suspension bushings, steering damper, etc) he replaced the swivel pin and steering joints and that made a huge difference. Also (and this needs to be done very carefully) he tightened the steering box slightly (about 1/8 turn). Overall that made a major improvement in the driveability of the vehicle. A member of the Range Rover forum, Rundeep_32, found 90% of his steering shudder went away when he replaced his shocks (he used Woodhead units sourced from DAP which appeared to have strong rebound damping and relatively mild comression damping).
I found this, it might help , as long as you did not change the diameter of your steering w. because if it is smaller then you will feel every thing a lot more ..
Saludos
