First I'd like to thank everyone who has contributed to these forums. I've learned quite a bit and have read and applied so many posts to the maintenance of my 04 Discovery.
So, I've a coolant leak from somewhere in the back of the engine, I can't determine exactly where.
After researching these forums I've decided it wasn't a HG problem because I have no mixture of coolant/oil anywhere, and the pressure is holding (I had it tested a few months ago) and I can feel the firmness on the coolant hoses.
I may have it tested again just for kicks.
From researching the forums I've decided the likely culprit, the Valley Pan Gasket, would be replaced first. Upon the removal process we discovered that some of the bolts on the "lowers" were loose (thanks Disco Mike). That may have been the problem right there. I decided to replace the gasket anyway since we were so far in already.
After completion, it still leaks, same area too. I am going to replace the Valley Pan Gasket again because I kinked it a little in when I was pushing it down trying to match up the holes. I want to make sure that this isn't the problem before going further.
So thats my nice little story, what I'd like to ask the forum gurus is:
Is/Are there any opinions or anything else I should be looking for when I go in again?
Probably going to do the work this weekend coming up.
Thanks everyone,
Stefan
Thanks everyone,
Stefan
