I bought this for a neighbor's RR Sport 3.0 and ended up not wanting to install it, so this is brand new - open box. I spoke with VR and they can change the tune for no additional charge to the Land Rover models listed below.
If you have a RR Sport 3.0 and then I would simply send it to you. If you have a different model I would send to VR for the specific tune to be uploaded, then VR would ship directly to you (at that point would be brand new).
Retail is $750.
$675 shipped
Fits:
2002-2012 Range Rover Supercharged;
2013+ Range Rover (3.0, Supercharged & 5.0 SVR);
2009+ Discovery 3.0; and
2017+ Discovery 3.0 supercharged
Please specify your Range Rover's information: Model, Year and Engine.
Manufacturer Info:
Get your Range Rover tuned with the Version 2 tuning box kit from AP Tuned. The tuning box kit is a plug and play solution to boost your Range Rover's performance up like an ECU flash, but without affecting your warranty. The AP Tuned ECU Tuning Box Kit gives your Range Rover power gains of up to 76hp & 74ft-lbs of torque depending on the engine.
Features:
With manufactures trying to increase fuel economy by adding forced induction to vehicles that previously had large displacement engines, the ability to tune them further is even more prevalent now. However there are 2 main issues with tuning these newer vehicles. The manufactures have gotten very particular about having their ECUs accessed to be tuned. These "anti tuning" features make it hard to read and write the ECU via the OBDII port. Some ECUs can be removed and flashed on the bench once the case is open. This is an immediate flag to the dealer which ultimately will void your powertrain warranty if a situation arose. This is where the AP Tuned Tuning Box Kits come into play over the competition.
Engineered for boosted cars, these vehicle specific plug and play kits are designed to easily be installed and uninstalled as needed. The harnesses feature OEM plugs that attach to necessary sensors where the pre-mapped tuning box gives your vehicle huge amount of performance gains. Unlike other "piggyback" solutions, these use high quality connections, wires, and casing that are designed to be engine mounted for longevity to the elements.
Each Tuning Box Kit has been engineered and tested to work in even the most extreme environments of altitude, temperature, and driving conditions.
Retail is $750.
$675 shipped
Fits:
Manufacturer Info:
Features:
- Made in Germany
- Plug and Play for easy install and removal
- No detection by dealer when removed
- Up to 7 different maps for easy programming
- Includes bypass plug to run as stock
- Does not lock to vehicle or VIN
- Harness has OEM style connectors, no splicing or cutting
- Tuning Box features a weatherproof case
- Digital Microprocessor Controlled
- Proven power gains tested on 93oct/98ron.
- Designed for forced induction vehicles only
- Tuning box cannot eliminate CELs caused by modification or removal of emissions control devices such as catalytic converters.
- Installation Instructions are included.
