1 - 6 of 6 Posts
Discussion Starter #1
Hi,
I recently had a problem with my 2000 model disco 2, whilst on the freeway felt like a gear change then the M and S lights flashing and the engine light on but the engine was still running and no throttle. Please assist.
Daren
Durban
RSA
Administrator
You need to better describe what is happening.
How old is your battery, are the cables clean and tight? When did you last service your tranny?
Low voltage can cause this to happen, might want to go have your battery/alternator tested and let us know what the voltage is.
Discussion Starter #3
Hi Disco Mike,
I could not drive the vehicle because of no throttle. Vehicle starts with no problem hence I think the battery is fine. I had to truck the vehicle back home. Light on the dash m,s and d flash and also D on the gear. Also engine stall light is on although engine is running. Thanks for your response.
Discussion Starter #4
Mike, I have the vehicle for 7 months only, not sure how old the battery is. Tried to check the cables but in a very difficult position.
Administrator
What do you mean by it has no throttle, be alot more specific.
1 - 6 of 6 Posts
