1 - 3 of 3 Posts
hi
myboot is soaking wet ofund where it is coming from ,in through the loom pass side to the tank sender and also has the drain for sunroof taped to it ,check the sunroof drain to see if it had blocked but ok , has anyone had similar problem or is it common?
ta mark
Former LR tech, Albany NY
try taking a hose and running it over the boot. Then localize it with the water to see where it might be coming from. It could be the strikers are a bit loose allowing water in.
hi
after taking the lot out of the inside of boot and running water over sunroof i found the pipe was kinked behind the rear seat belt just as it exits the rear wheel arch ,
so it leaked into the boot .ill keep an eye on it and put it all back tommorow .
ta mark
1 - 3 of 3 Posts
