Hey Folks,
Symptom: Passenger side low-beam no workie. Headlight bulb OK. I checked all voltages and here's what I have:
-At battery while running with and without headlights = Aprx. 14.4v
-Voltage at headlight plug that does not work 11.4 - Not Running
-Voltage at headlight plug that does work 11.6 - Not Running
I took the drivers side headlight unit and plugged it into the passenger side and the low beam works! Put it all back and no workie on passenger side again. I have inspected the unit and it's clean and I also have continuity with the 2 wires from the plug of the unit to the 2 wires that the bulb actually plugs into.
What I don't get is when the non-working unit is plugged in and I have the bulb hanging out, I'm getting the 11.4v right on the bulb ?!?!?!
Is it possible that 11.4 is just not enough to light it up? Is 11.4 or 11.6 normal at the bulb if I have 14.4 at the battery?
I'm really trying not to buy a new headlight unit. Mine is very clean and I should be able to get this working, I hope ?????
Thanks!
Thanks!
