anybody help on poss causes of water getting into drivers footwell? i have a very squishy carpet on the righthand side of the drivers footwell close to where the door shuts to thanks
a/c drain pipe has been cleared and its not coolant, its water, any other suggestions?Disco Mike said:Is it coolant or water?
If it is coolant it is from the heater core if it is water could be water leaking in from the A/C because the drain pipes are plugged.
Mike J.
thanks for advice but it hasnt got a sunroof! could it be door seals?rovertech said:i would check the sunroof drain tubes they r difficult to get to but can get clogged with leaves. if you pull the a pillar trim you can see the drain tubes or you can open the roof and do a visual inspection and blow air through the lines![]()
