We have a Discovery II and I'm starting to change everything over to Amsoil synthetic.
LUBRICANTS & FLUIDS
Engine Oil
Grade 1......SJ
SAE 10W-40 Synthetic High Performance Motor Oil
-4 to 95°F......10W-30
Above 32°F......10W-60
Above -4°F......10W-40, 10W-50
All Temps......5W-40, 5W-50
Below 95°F......5W-30
Automatic Transmission,ZF 4HP22.....AF3[1]
Synthetic Automatic Transmission Fluid
Automatic Transmission,ZF 4HP22.....AF2
Differential, .....GL-5[2]
75W-90
Series 2000 Synthetic Gear Lube
SAE 75W-90 Synthetic Gear Lube
Transfer Case,LT230.....GLS[3]
Fluids
Power Steering Fluid.....PS
Power Steering Fluid - Not Available Through Amsoil Click here for more
information
Brake Fluid.....HBH
Hydraulic Brake Fluid, Extra Heavy Duty - Not Available Through Amsoil
Click here for more information
1. Alternate lubricate.
2. GL-5 is a synthetic gear oil.
3. Land Rover recommends Texaco Multi-gear 75W90R
CAPACITIES
Engine, with filter..........6.1 quarts[1]
Engine, with filter..........6.7 quarts[2]
Engine, with filter..........6.9 quarts[3]
Engine, with filter..........7.4 quarts[4]
Cooling System, Initial Fill..........14.0 quarts
Automatic Transmission, Total Fill
ZF 4HP22..........10.0 quarts
Differential, Rear..........3.4 pints
Differential, Front..........3.4 pints
Transfer Case,LT230SE..........4.2 pints[5]
Transfer Case,LT230SE..........4.9 pints[6]
1. Refill capacity shown (engine without oil cooler).
2. Refill capacity shown (engine fitted with oil cooler).
3. Dry fill capacity shown (engine without oil cooler).
4. Dry fill capacity shown (engine fitted with oil cooler).
5. Refill capacity shown.
6. Dry fill capacity shown.
