1 - 10 of 10 Posts
Hello All:
Can anyone tell me about the construction (ie. are the body panels aluminum?) and any mechanical specs on a 1992 Range short wheel base?
How big is the engine? What kind of transmission? What are the specs on the drivetrain??? Does the 4 wheel drive system lock up in low range? Limited slip or open diffs???? Any info would be helpful!
I am new to the Rover world, and we have a nice 99 Disco II and this Range Rover that I hope to conquer the winter with, both acquired within the last month.
Thanks!!!!!!
Some of the panels are aluminum. A good way to tell is "look for rust". Just kidding.
It's a 3.9 liter. ZF transmission.
The axles are not locked in low.
I'm sure some of the other fellows will chime in.
Well you have a 3.9L engine, you have viscous coupling transfer, you are not locked up!! I believe the gears are 3.54:1! The hood and upper tailgate are not aluminum, rest of the body is. I have a 92 RRC and it does great in snow....Wish I had my snow-wheeling pics on the net I'd show you...You will be just fine...Here are some summer shots of my rig so you know what yours in capeable of!!
Not quite true
Aluminium doesn't respond well to being stretched round tight corners in the press-shop, so all the small radius panels are steel: hood (bonnet in UK), rear quarter pannels, upper AND LOWER tailgate, not to forget the basic body frame. Add water and you've got a self-propelled battery fizzing away, pity we can't use that instead of petrol!
learn something everyday!!!! Thanks Geoffrey! :D
-Aluminum: Front fenders, roof, door skins, rear quarter panels, cowl
-Steel: Hood, lower tailgate, upper tailgate, rear quarter caps (tail light mount in these), unibody (everything under the skin), frame, sunroof panel
-Engine: 3.9 liter alumium block & cylinder heads with cast iron liners, derived from a 1960s General Motors design, Lucas/Hitachi hot wire EFI system
-Transmission: ZF 4 speed automatic with lock up torque convertor, tough unit, used in large European sedans (BMW,Jaguar), light duty trucks (Ford) and medium duty trucks in Europe
-Transfer case, Borg Warner silent chain drive with viscous lock up differential
-Axles: Salisbury differentials, full floating hubs with Timken tapered roller bearings
-Brakes: Wabco 4 channel anti lock system
cellulararrest said:
I think the Hunter was only in 1991? Not sure about that. All I know is it didn't last long.
My RRC is actually a 91, it was built so late in the year that it was considered a 92....So you are correct!!!!! It makes finding a few parts a bit different...such as I don't have ABS but I use the same front brake pads as one that does....Go figure!!!! good call cellulararrest!!
...-Steel: Hood, lower tailgate, upper tailgate, rear quarter caps (tail light mount in these), unibody (everything under the skin), frame...
Remember this when you wheel in mud - it is imperative that you wash it all off - unless you want to be replacing this... I have two very very large holes in each front floorboards because previous owners did not take keep an eye out for this - plus many small holes all over the place.
Not going to be a fun job to do.
1 - 10 of 10 Posts
