1 - 7 of 7 Posts
Hey guys, as you probobly know(or don't), I purchased my 95 Disco I this summer. It is lifted 2"(or 3" I'm not sure) and is running 33" Interco trxXus tires. I havn't really had any major maintenance, just repairs(go figure? lol). I'm up in the mountains so I'm going to have the oil changed for the arriving cold weather, as well as fluids changed/topped off. I want to have them grease my drivetrains and suspension also, because I'm hearing a grinding/grumbling noise when I let off the gas as speeds usually under 10-15 mph. I was wondering what else, realativly inexpensive, should I have done to my baby? Please list the brands and types of fluids/oils you reccomend, as I'll take note of them when I bring her in. Also, my leather seats are tearing a tad in the front. I've applied leather conditioner to them to maintain the good parts of it, but what options do I have in this area? They're not across any segments, they're isolated. I appreciate all you're input and hope to get some new pics of her up(I know, I'm not the quickest with pics lol).
Thank You, AppStateDisco
Discussion Starter · #2 ·
bump
7,500 MILE SERVICE
Exterior Add 16 oz Land Rover Fuel Conditioner (LRN5010)
Inspect wiper blades
Under Vehicle *Change engine oil and replace filter
Inspect tire pressures, condition and tread depth
Inspect brake pads, calipers and discs
Inspect trailer hitch attachment bolts for tightness
Change front and rear axle oil
Record performance of Service in Passport to Service
15,000 MILE SERVICE
Lubricate door locks, check straps
Lubricate hood latch and safety catch, fuel door hinges
Interior Check parking brake (Adjust if necessary)
Check seat belts
Under Hood Inspect coolant hoses
Inspect radiator and AC condenser
Check power steering fluid level/ACE fluid level
Clean battery and terminals
Inspect serpentine drive belt
Check brake fluid level
Perform body corrosion warranty inspection
Inspect exhaust system and heat shields
Inspect brake lines
Lubricate drive shafts and U-joints
Inspect steering rods, joints and dust covers
Inspect shock absorbers
Inspect suspension links and mountings
Inspect wheel speed sensor and height sensor wiring
Inspect fuel and hydraulic lines
22,500 MILE SERVICE
30,000 MILE SERVICE
Replace Alarm handset batteries
Check seat belts
Change brake fluid
*Replace air-cleaner element
Change engine coolant
Inspect brake lines
Change transfer gearbox oil
Change transmission fluid
Replace transmission fluid filter
Check front and rear axle oil level
37,500 MILE SERVICE
45,000 MILE SERVICE
Check seat belts
Replace serpentine drive belt
Inspect brake lines
Inspect engine and transmission mounts
52,500 MILE SERVICE
60,000 MILE SERVICE
Check seat belts
Change brake fluid
*Replace spark plugs
Inspect brake lines
Service SLS filter (if equipped)
back to top
* Required emission maintenance
Ouch, was that necessary, my eyeballs hurt!
The grumbling sound is probably the sound of the tires.
NEW GUY
If you have never done any service I would change all the fluids and filters
Change oil & Filer
Change trans fluids and fitler
Change fuel filter
Change T-case fluid
Service both rear
Gease all suspenion fittings
check brakes lube claiper slides
clean and grease wheel bearing
check the front end for play
Change coolant as well
I noticed the long list for each set of mile services , but if i have 94k on the odo , and the only thing that has been done is a oil change , what else do i need to do , at this point ?
( Only things that are important , to improve , and make my rover last past 100k)
NEW GUY
Service everything.
TRANS
REARS
T-CASE
CHANGE COOLANT
FUEL FILTERS
TUNE- UP
Its good to know that it all been done after you do it all
Its better to spend a little now than alot later
1 - 7 of 7 Posts
