You are absolutely correct. I had that problem on my Disco. Must be a common problem.LRR219 said:drivers side top end, rockers a possibility? The flange at the top of the cat tends to break and can be welded again if yer lucky... just another worthless opinion hope it helps.... c-ya
Landy-Andy said:Here is a list of ticking causes, starting the list with the easiest to fix down to the hardest....
-Leaking exhaust manifold (tighten bolts or replace manifold gasket)
-Cat's can tick when insides become loose(put a long self tapping screw through the middle of the cat, which holds all the insides tight) or replace Cat.
-Hydraulic lifters, (can be adjusted) Should be able to hear this as soon as engine is first started (still cold).
- Loose cylinder lining - these move up & down when engines get to high mileage, causeing a ticking sound (you dont normally hear this at cold start up but as things get warm the liners exspand & they begin to move - I have heard of people just living with this for years (not much you can really do for this except total rebuild or new engine).
I hope your ticking is at the start of the list!
Good luck,
Andy
I think the cats rattle when the inside becomes loose, right?Landy-Andy said:Here is a list of ticking causes, starting the list with the easiest to fix down to the hardest....
Good luck,
Andy
WTF???myhomescape.com said:They are going to replace it by removing the cat and putting a straight pipe in.
Not illegal here. No emission requirements here in Alberta, Canada.OkieRover said:WTF???
What kind of dealer would do that?
That is ILLEGAL in my state (Oklahoma) and we don't have near the laws that California has for emissions. Nor the testing requirements.
Wow!I am shocked, really.
