I need the upper and lower u-joints on my steering shaft. I figured that I might as well change out the rubber coupling while I had it out. Where can you get the upper u-joint? I can find the coupling and lower u-joint anywhere, but the upper one seems to be scarce. It looks like most of the complete shafts that are advertised are only the lower section. Does anybody know? Thanks.
