1 - 8 of 8 Posts
I am going crazy with this noise and I for the life of me cant figure it. I have changed tranny fluid, both diff fluids, transfer case fluid and greased driveshafts. I am begging somebody to listen and tell me what it is. It occurs when letting off gas and coasting. Here is the noise, give it a shot PLEASE! This is the best recording i could get.
Mr. t
Can you explain at what points it happens? Like during decel, Etc..
Sent from AutoGuide.com App
noise
It occurs when letting off the gas and coasting, like before you come to a stop sign it stops when the vehicle is almost at a stop. But definately any time i let off the gas and it starts to slow.
Are you sure its from the transmission? How about a bad bearing in the alternator or a loose belt.
If it was that it would do it all the the time I would think, not just when coasting?
I can't say from hearing it but noise travels. Perhaps a pinion bearing going bad? Doesn't sound like the usual growl, but perhaps worth checking? They usually growl when you let off the gas.
1 - 8 of 8 Posts
