**first post**
Rear windows would not go up or down on my 97 disco. Both front windows would go up and down fine. I read that this is a common issue with a dry node on the Windows ECU circuit board.
I re-soldered a couple places on the ECU to make sure everything was "wet", hooked it back up, and found more problems. Now, the back windows go up and down and the front passenger window goes up and down.
As for the driver's window, it was up when I plugged in the ECU to test. I tested it going down and it went all the way down. I toggled it up and nothing. No motor sound, just click. The motor sound still occurs when toggling down (even though it doesn't go any further down).
This is a window that was going up and down an hour before, so it can't be the motor or regulator right? Would be some kind of coincidence if that motor went out in that hour. I must have screwed up the ECU right?...Anyway, about to rip the door panel (and my hair) out.
Thanks for the help.
