1 - 8 of 8 Posts
Discussion Starter #1
What are my options to fix a partial missing window seal? I looks like about 8 inches or so is missing on my rear pas side. This is the part inside the track that window slides into.
1) where do I get this?
2) how the heck to do you replace it? Is it difficult?
very disco
If you’re talking about felt-type material within the window’s a-frame, it may have come loose and slid downward into the door.
the entire a-frame comes off with just a few bolts in the jamb, but removing the window is a real chore. You might just pop the door card and see if the seal can be slid back up.
Reverend is right, the felt like part might have slid down.
I had this exact issue when I picked up my Disco. Don't really recommend but I spray silicone and used a large flat head with extreme patience and pushed it back up.
You can take off the black window rail it's not difficult but I would try just moving it up first.
Super Moderator
Yup same happened on my truck, pulled it back up and applied silicone spray in the window channel
Been fine ever since
very disco
Is the silicon spray to prevent the window from dragging it back down?
Super Moderator
Yes
Spray can stuff, same as you would use on all door weatherstripping
Discussion Starter #7
Thanks all. I'll see if it slid down and update.
Discussion Starter #8
Thank you!! Sure enough....pulled it right back up with some neednose plyers.
  • Like
Reactions: reverendALC
1 - 8 of 8 Posts
