1 - 6 of 6 Posts
My driver door lock seems to be giving me some issues. The ignition though is fine. Id like to replace both soI don't have two keys. Anyone have a door lock, ignition switch and key they want to sell?......at a fair price?:)
'03 Disco SE
What issues is it giving you specifically? Maybe the it spins freely when you insert the key and doesn't unlock anything? If so, it's likely the pin that links the door lock to the actuator. The OEM version is made of sintered pot metal that almost always breaks. There are a couple of sellers on ebay that are offering an aftermarket steel version that seems to be much higher quality.
Land Rover Front Left LH Driver Door Handle Pin Discovery II CXB103030H | eBay
If you opt for the whole lockset you're looking at $150 + $75-$150 to program the key with a Testbook.
Discussion Starter · #6 ·
I'm the second owner and the only key I received with the lr is a non fob copy. plus the door lock looks like a drunk went at it. but to answer your question I haven't looked in the door yet at the lock. I just had it apart to re place a window regulator and didn't really want to pull out off two more times. I had just decided to go new or use new
1 - 6 of 6 Posts
