THIS^^Try cracking the bleed screw while holding the revs up - sometimes there are super stubborn bubbles that need to be forced out. It took me like 5 tries to fully bleed my truck when I redid the head gaskets, water pump, and radiator about a year ago.
It'll seem like that but you will get more air out. Crack it farther, give it some more revs, and see what happens. Or keep driving it and get the revs up and see what happens.I cracked the bleed screw and ran it at 1500+ rpms and it seemed to (still) have a steady stream.
Drove it and still at 200 driving 205 idle. I'll keep driving it and see what I see.
Agreed, it will seem good, but in reality it’ll get air out. This method makes a mess, there’s no doubt about it, but it does work. Just takes some time.It'll seem like that but you will get more air out. Crack it farther, give it some more revs, and see what happens. Or keep driving it and get the revs up and see what happens.
Land Rover Discovery 2 Inline Kit (inlinethermostats.com) Did an inline t-stat mod last year. Running 177-190. 180 on average. 190 on hot days or extreme conditions. I struggled for years with the 180 degree LR model t-stat pushing as high as 235 degree on 100+ degree days. Plus, any issues, hit autozone, grab a Chevy t-stat and install, no waiting for 3-5 days for a new plastic bottle t-stat.Further report:
In Phoenix and it's only 66F out.
Idle temps get to 205 and it did touch 207 briefly, but mostly staying right around 198 to 201.
Am I paranoid?
Do you blame me?
Thanks for your comments and input - appreciate it!
Mike, that seems a bit high to me for this time of year here bro.Ran it all day yesterday letting idle most of my stops. 194 on freeway. 199 most of the time with the occasional 205 but dropped immediately from stop. Hmmmm🤔
i have a factory manual and it says 212f is operating temp but you can get a inline thermastat look on youtube it bypasses your factory thermastat and you can easily replace it with a 160 etc easilyThis is my same old truck - just reclaimed from the Mrs. and now no longer her daily driver.
I think the tstat stuck and caused radiator failure.
I replaced the radiator and upon my test drive after noticed the bottom hose literally cold (not even warm) - so replaced tstat.
Now, bottom hose is warm like it should be, but still reading these temps.
Raised the reservoir when filling like I always do and full stream out of bleed screw like normal - seems like it's bled.
I've done like 6 reservoir replacements so I think I have the fill part down ok, but shucks still not sure why I would temp would be 205.
PS - fan clutch feels good, good resistance.
