Arm Rests
2.5K views 1 reply 2 participants last post by  Paul Grant
#1 ·
Does anyone know how to remove the movable arm rests from an '89 Range Rover...I know you need to go in through the back of the seat, be where do I go from there?
Thanks
#2 ·
IIRC it's just a mater of a couple of bolts that hold the arm rest in place. They are either 7/16th or 10mm. Once you remove the hardshell seat back you'll see the two bolts that need to be removed. As long as you are careful removing the seat back the rest is easy.
