Let’s Break The Myth, Lr3 Keys Are Not Really That Expensive, The Key Must Be Cut By The Factory, Not The Dealer, Unless It Is A Big Ny Dealer Or Something That Has The Laser Machine. Cost About $12 To Have The Key Cut. Go To The Dealer With Proof You Actually Own The Lr And The Vin Number And They Will Get You The Key.
The Fob Can Be Bought On Ebay For $10 Or So, But Be Sure It Is The Correct One, The One I Got Matched The Numbers On The One I Had, So All Was Good.
The Dealer Will Program The Fob For You In About ½ Hour At Their Rates Per Hour (shop Around If The Dealer Wants $300 For This!) This Should Cost About $40, More Than A Ford, But Then You Are Not Driving A Ford; You Are Driving A Luxury, Beautiful Truck.
Be Sure You Take All Fobs You When You Go To Programming Otherwise You Will Be Screwed! If You Cannot Afford This You Should Have Bought A Ford!
