Saggy bottom
1 reading
2.3K views 4 replies 5 participants last post by  p76rangie
#1 ·
Hi all,
My Series 3 88" (Santana) 1983 seems to sag at the back. I usually use it to collect 1 ton of sand (in a trailer) ,on road or go down the country lanes to the river, off road and it seems to have a low rear end. My question is....do i need new leaf springs and if so which type would you recommend and what extra parts might i need. I realise this is basic to most of y'all but its all a bit new to me and money is limited.
Many thanks
#2 ·
I would think that you should be able to have a local spring shop /truck suspension shop rebuild your existing leaf springs, you might even consider possibly adding an additional leaf?
Ask around, find out who is reputable in your area.
#3 ·
If you have the capability to do some basic fabrication, your best bet would be to add in a set of air bag helper springs. That truck was not really designed to be a freight hauler. Every spring setup is a compromise anyway- if you add in more spring, it's going to be stiff as hell when unloaded. Even the helper style spring that theoretically only engages when loaded adds stiffness during regular use.
I have a set on my Excursion that occasionally sees some tongue weight on it. The bags make a world of difference. Without them, the truck would be un-driveable with my boat hooked to it.
#4 ·
If you want to just go the stock-ish route there are companies out there that offer uprated springs and parabolic springs
