the way I have done this tasksome dozen times is a s follows, drop the steering wheel column after demoving the knee bolster, remove the left side bracket which holds the dash to the kickpannel, remove the lower center bracket at tunnel left side, go to the right side, remove glove box follow by removing the remaining two brackets matching oposite side....wiggle the whole dash out wards until it stops as if you intend to drope it on your lap (about 1/2 a foot to a foot).
take a bungee cord, goto the rigth side seat wrap the bungee around the head rest... pull up and out on the glove box opening to raise the dash 1/2 way p the right pilar, tie the bungee to the glove box opening...
at this time if you have power seats you can use the seat to recline and back position to gain a little room...
crawl under dash on passenger foot well area and access the heater box and you heater core..... total time to remove, replace, fill cooling system and test about 2 to 3 hrs...
mind you, my method is completely different from removing the whole dash assembly followed by removal and dissasembly of heater core as factory manual recomends...in 8 plus hrs.
off warranty and extended warranty dealer charges between 12 to 18 hrs.....
