trans wont go into any gear,no codes
4 reading
33K views 18 replies 5 participants last post by  skinny
#1 ·
newbie..i have a 1996 range rover. idrove the car and it ran and shifted fine.today i started the car to warm it up but when i went back out to leave it tried to move in reverse but stopped. now it will not go into any gear.there is no fault code or trans neutral light on.locks in park and you can push it when it is in nuetral...any help or ideas would be more than welcome....:confused
#4 ·
Be sure the tranny fluid is correct, when following the instructions on the dipstick. If it is over full, then correct that first.
Next, if the gearshifter is moving freely and its displaying the correct gear selected, I would check that the linkage on the tranny is still hooked up and turning the selector shaft on the side of the transmission. It will be on the drivers side of the tranny and easily visible. If you suspect that, you can remove the nut and the linkage, then select a gear by hand. Although with you being able to put it into neutral this doesnt sound too promising. Free and quick to check though non the less.
Being able to put it in park and that stopping the rig, then rolling it freely in neutral, kind of rules out the transfer case for the most part.
Any noises etc when you try to put it in gear?
Or when it tried to reverse under its own power?
Martin
#7 ·
If the transmission is stuck in Park, the cause can be a blown fuse (check the fusebox under the RH front seat) or failure of the brake light switch. As Gill964 reports, "The result of an inoperative switch is no brake lights which does not allow you to take it out of park. The brake switch is located just behind the brake petal about an inch long and black. Replacement cost less than $40 US".
#8 ·
You guys aren't real familiar with the P38, are you?
If the shifter and instrument panel are indicating that the transmission is in a gear other than park, the shift lever is doing its job, the cable is doing its job and the arm on the side of the transmission is doing its job.
At this point, we should think to disconnecting a cooling line and looking to see if we have fluid flowing.
#10 ·
Clean? On a Rover?
There is no reason to bother. We know that this function is working as the switch that indicates what gear the transmission is in cannot move unless the shift cable is turning the arm.
We have proof the shifter is working by virtue of the instrument panel display, and the ability to put the vehicle in neutral and roll the vehicle.
#11 ·
i got the fluid right,i also checked the shifter from under the car...it works...still nothing.i will disconnect a cooling and see what i get...if no flow what does that mean...new trans or new pump......thanks for the help..
#13 ·
where should i take the line a loose from.. rad or trans. also does the pump come and go like that. the reason i say this is that the guy that i bought it from told me that it would not go into any gear. i bought it knowing this. i towed it home and it also needed a fuel pump. i replaced that started it up and it drove like brand new. brought it home home,sat for a few days. now this....:bawling:
#14 ·
On the lines, take your pick.
You can either fight with the transmission side top line for 1/2 hour then get soaked, or undo the lower line and still get soaked.
OR, you can undo the line on the cooler side and hope and pray it doesn't break the fitting off the cooler:mad:
Ideally I would shoot for the line on the cooler. Easier to get to and will show flow a little better in a controlled manner. But there is the risk of it breaking the cooler if it's corroded pretty bad. I have had them go both ways, and it's about a 50/50 chance.
If it didn't go into gear when you bought it, then sounds like it gave its last effort when you moved it.
Could be a trashed torque converter too though if it has been broke for a while (would have been nice to get ALL the information off the bat;)).
Either way at this point, tranny is coming out by the look of it so far.
Martin
#15 ·
Or, you can cut the line with a rotating wheel tubing cutter and reassemble with a double compression fitting.
My experience has not been positive when confronted by such issues.
#17 ·
broke down and took it to the trans shop...trans is shot...pump,drum.seals///said it had been in before...would cost too much to rebuild...found a used one for $600.00. thanks for all of your help......will let you know if it works....... :eek:(
