We're working with a '97 Disco, 167k.
Valve Adjustment:
I've had a self proclaimed Disco expert assure me that I have adjustable valves and that it's important to have them adjusted at least annually if not every 6 months depending on how many miles you put on. I'd like to throw that statement out to the forum for opinions. Keep in mind I bought the truck at 80k miles and have never had it done, and I have the knock issue below that may or may not have something to do with valves.
Alternate Thermostat Temps:
I'm running the stock 195 temp thermostat but would like some feedback from anyone who has tried running the lower 160 or 180 deg thermo's. I recently relocated to south Florida so keep that weather in mind as you guys from Minnesota are typing how stupid I am. I realize I'm risking the dynamics of the ECU and how other systems may perform. If any of you are running them in hot weather areas, are you seeing ENOUGH of a difference in your cooling system performance to warrant the replacement? FYI I'm not trying to solve an existing problem within my system, it seems to be performing well as is. I'm planning on a pop-up or small travel trailer for the summer and I'm considering the thermo change and an electric higher flow radiator fan to help boost the system just a bit.
Engine knock:
Starting from cold she's quiet as a mouse. The knocking/ticking develops as it reaches operating temp. I only run premium fuel. I'm running 10w40. All my fluids are fresh, clean, and at level. My first thought is a partially blocked oil channel that is allowing the 10 weight through fast enough at cold start but as it heats to 40 weight the flow slows enough to cause problems. I'm going to start by pulling the sump and checking the oil tube screen for blockage as well as the sump and filter for metal. Then run an oil pressure test. Rave suggests that if I see ANY metal in my sump then short out my ignition to my spark plugs one at a time and when the knock disappears I'll know that big end bearing is gone. That's worst case hopefully. I'm not noticing any power loss or other performance issues. At 167k miles I'm very hesitant about going the Autozone route of a bottle of Seafoam and hoping for the best. I can deal with a new oil pump and new heads if it's lifters or valves, but at my mileage if I'm looking at pulling out the whole engine to get at big end bearings I may as well look at a lower mileage used engine right? I'll probably pay less in the long run if mine has to come out anyway. Anything I've missed throw it out there. Thanks
Valve Adjustment:
Engine knock:
